Group: DynoMotion Message: 4003 From: Dennis Date: 2/20/2012
Subject: Auto Tool Zero wiring
I'm in the process of getting everything together to setup a auto tool zero routine using Mach3 and a KFlop board.
My router is a Porter Cable 7518 and it doesn't have a ground lug on the plug. I'm not sure if that means all of the electronics inside are fully insulated from the metal body or not. When I dissembled my last PC 7518, I don't remember seeing anything that contacted the metal body.
So, with that being said, would I wire it like this?:
IO34(JP6, Pin 15) on my KFlop would connect to the motor housing, since this input is pulled low.
VDD33 (JP6, pin3) would attach to the touch off plate.
I'm thinking of wiring this way because if the router body is connected to earth ground and I connect the +3.3VDC (VDD33 (JP6, pin3))to the router body, I'm essentially causing a direct short to the negative side of my DC power supply, which is bonded to earth ground.
Dennis
Group: DynoMotion Message: 4004 From: himykabibble Date: 2/20/2012
Subject: Re: Auto Tool Zero wiring
You should ground the case of the router. Then attach a stiff pullup resistor (300 ohms or so) between 3.3V and any unused I/O, and configure that I/O as an input. Connect that I/O to your touchplate. When the tool touches the touchplate, the input will go low.
Ray L.
> Thanks,
> Dennis
Group: DynoMotion Message: 4005 From: quelisto Date: 2/20/2012
Unsolicted advice...if you have a Kanalog, use one of the opto inputs instead of a LVTTL input. The 3.3v LVTTL i/os are REALLY sensitive. I've had Kflops reset because someone touched or even just brushed past an insulated wire - just the capacitive interaction was enough. To say they are susceptible to stray electric field interference is an understatement. As an alternaitve to using a Kanalog opto input, make your own optoisolated interface to a Kflop with a 4n35 or equivalent.
> Regards,
> Ray L.
> > Thanks,
> > Dennis
Group: DynoMotion Message: 4006 From: Dennis Date: 2/20/2012
Hey guys, thanks for the advice.
The Kanalog is on the wish list, but right now I just have the KFlop.
Would the router be attached to the digital ground, i.e. JP6, pin 8 or 9?
Dennis
> > Regards,
> > Ray L.
> > > Thanks,
> > > Dennis
Group: DynoMotion Message: 4007 From: himykabibble Date: 2/20/2012
Just for safety sake, the router should be grounded to your system ground, NOT directly the KFlop. You should have ALL the grounds in your system tied together at one common point.
Ray L.
> Thanks,
> Dennis
> > > Regards,
> > > Ray L.
> > > > Thanks,
> > > > Dennis
Group: DynoMotion Message: 4009 From: Dennis Date: 2/20/2012
So let me see if I'm understanding this right.
1) Ground the router to my common grounding strip which is tied to earth ground.
2) Tie all unused inputs to +3.3VDC with a 300ohm resistor to pull them all high. (I'm assuming this is to avoid floating i/o.
3) Attach the touch off plate to one of my inputs from step 2.
Once all the above is complete, when my tool that's tied to earth ground touches the plate that's connected to the high input, the input will be pulled low.
Does this all sound correct?
Dennis
> Regards,
> Ray L.
> > Thanks,
> > Dennis
> > > > Regards,
> > > > Ray L.
> > > > > Thanks,
> > > > > Dennis
Group: DynoMotion Message: 4011 From: quelisto Date: 2/20/2012
All of that is very good advice (especially the common point ground), but I would still insist that use an optocoupler between your input and your touchplate. Otherwise, you could get false triggering at the very least, and possible board-level damage if an ESD discharge occurs on the input. You can buy optocouplers for about each $2 at Radioshack, or ~$1.00/ea. from Digikey/Mouser/Jameco/Newark/Arrow if you can stand to wait a few days for the mail order to arrive.
For anything that is to last in an industrial/prosumer hobbyist machine tool environment, you need to use optocoupled inputs, it's just cheap insurance for the Kflop, and it will elad to FAR, FAR less false triggering (both because of the isolation as well as the low output impedance).
-Erik-
> Thanks,
> Dennis
> > Regards,
> > Ray L.
> > > Thanks,
> > > Dennis
> > > > > Regards,
> > > > > Ray L.
> > > > > > Thanks,
> > > > > > Dennis
Group: DynoMotion Message: 4012 From: himykabibble Date: 2/20/2012
Tie *one* unused input to 3.3V through a resistor. Use that input as your touchplate input.
Ray L.
> Thanks,
> Dennis
> > Regards,
> > Ray L.
> > > Thanks,
> > > Dennis
> > > > > Regards,
> > > > > Ray L.
> > > > > > Thanks,
> > > > > > Dennis
Group: DynoMotion Message: 4014 From: Tom Kerekes Date: 2/20/2012
Hi Dennis,
I agree with Erik.  KFlop's 3.3V inputs will be damaged if ever driven above 3.9V or below -0.6V.  They have ESD protection but there is a limit to what that can protect against.  Running an input pin 10ft away and directly connecting it to an exposed plate that then connects to a noisy earth ground is almost asking for trouble.  Earth grounds can often have 10V of voltage spikes or more.
If you don't have an opto coupler then as a variation of Ray's method place a resistor in series to the input pin near KFLOP to help protect KFLOP.  A 10V spike on the touch plate will then just feed ~10ma into the input and not cause any damage.   So for example do:
+ 3.3V
300 ohm
---X------------ 1K ohm ------ >  KFLOP Input
   |  (long wire)
Touch Plate/GND
Group: DynoMotion Message: 4015 From: Dennis Date: 2/20/2012
Thanks guys!
So Erik, I just ordered a few 4n35 from Jameco. Could you enlighten me on how to hook them up? I'd really appreciate it.
Here is the link to the Jameco product page. There's a link to the spec sheet on the page.
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=41056&catalogId=10001&krypto=9x3mj8umRTr2bLyjAD4Fael1vVWROgEFk3%2B6V3qZSImRVD9qn3OegA%3D%3D&ddkey=http:StoreCatalogDrillDownView
Dennis
> Hi Dennis,
> + 3.3V
> 300 ohm
>    |  (long wire)
> Touch Plate/GND
> From: quelisto <quelisto@...>
> Sent: Monday, February 20, 2012 6:44 PM
> Subject: [DynoMotion] Re: Auto Tool Zero wiring
> -Erik-
> > Thanks,
> > Dennis
> > > Regards,
> > > Ray L.
> > > > Thanks,
> > > > Dennis
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Thanks,
> > > > > > > Dennis
Group: DynoMotion Message: 4017 From: Tom Kerekes Date: 2/21/2012
Hi Dennis,
Smart.  The idea would be to have about 20ma of current flow and turn on the LED when the touch plate is conducting.  Those devices have a CTR (current transfer ratio) of 100% min which means 20ma through the Diode will allow the output to conduct at least 20ma on the output.  To save one resistor you might use one of the first 8 IO on JP4 or JP6 which have internal pull down resistors of 150 ohms.  You can power the LED from any voltage 5, 12, 24V just adjust the series resistor to get about 20ma.  So for example using 12V the series resistor would be ~10V/0.02A = 500 ohms.  (Power dissipation of 10V x 0.02A = 0.2W).
+12V
500 ohm
Opto LED pin 1
Opto LED pin 2
Touch Plate
Earth GND
DC GND
+3.3V
Opto Collector pin 5
Opto Emmiter pin 6
KFLOP input with Pull Down (ie JP4 Pin5)
Group: DynoMotion Message: 4019 From: quelisto Date: 2/21/2012
Yep, I agree with Tom on this. Here is an ASCII pictogram of the "wiring" if you will for the 4n35 optocoupler circuit. Pin 3 is not connected, and you need not connect pin 6 either, though it may be wise to connect it to ground via a decoupler cap (0.1 uF is what I've shown here). P stands for "pin".
+12V KFlop Gnd
| = 0.1 uF ceramic or NC
| _________ |
|__|P1 P6|___| ____________Kflop LVTTL input
__|P2 P5|______|___/\/\____ +3.3V
| | | R = ~3kohm
| |P3 P4|____
| |_________| |
- Touchplate Kflop Gnd
- Router body
Common point power gnd
> Hi Dennis,
> +12V
> 500 ohm
> Opto LED pin 1
> Opto LED pin 2
> Touch Plate
> Earth GND
> DC GND
> +3.3V
> Opto Emmiter pin 6
> From: Dennis <dennis@...>
> Sent: Monday, February 20, 2012 8:37 PM
> Thanks guys!
> Thanks,
> Dennis
> > Hi Dennis,
> > + 3.3V
> > 300 ohm
> >    |  (long wire)
> > Touch Plate/GND
> > From: quelisto <quelisto@>
> > -Erik-
> > > Thanks,
> > > Dennis
> > > > Regards,
> > > > Ray L.
> > > > > Thanks,
> > > > > Dennis
> > > > > > > Regards,
> > > > > > > Ray L.
> > > > > > > > Thanks,
> > > > > > > > Dennis
Group: DynoMotion Message: 4020 From: quelisto Date: 2/21/2012
Wow, that's strange, when I see this on the forum, the ASCII-gram is garbled. when I'm doing this reply, the picture is restored. So, hit "reply" and you'll see my picture. Sorry, I don't know what it is about the formatting that wrecks it.
> +12V KFlop Gnd
> | _________ |
> | | | R = ~3kohm
> | |P3 P4|____
> | |_________| |
> - Router body
> > Hi Dennis,
> > +12V
> > 500 ohm
> > Opto LED pin 1
> > Opto LED pin 2
> > Touch Plate
> > Earth GND
> > DC GND
> > +3.3V
> > Opto Emmiter pin 6
> > From: Dennis <dennis@>
> > Thanks guys!
> > Thanks,
> > Dennis
> > > Hi Dennis,
> > > + 3.3V
> > > 300 ohm
> > >    |  (long wire)
> > > Touch Plate/GND
> > > -Erik-
> > > > Thanks,
> > > > Dennis
> > > > > Regards,
> > > > > Ray L.
> > > > > > Thanks,
> > > > > > Dennis
> > > > > > > > Regards,
> > > > > > > > Ray L.
> > > > > > > > > Thanks,
> > > > > > > > > Dennis
Group: DynoMotion Message: 4021 From: Michael Rosenfield Date: 2/21/2012
Or, you could use an I/O module instead. They are a bit more expensive, but you don't have to deal with wiring up integrated circuits that way. There are terminal boards available for them, too.
I've recently purchased several sets off Ebay for not much money. There are input modules and output modules available, and AC or DC varieties of each.
Michael Rosenfield
Group: DynoMotion Message: 4031 From: Dennis Date: 2/21/2012
Thank you guys for the information. I'm very excited to get this going. I think my 4n35's should be here tomorrow.
I've uploaded a couple of schematics, one with and one without the pull up resistor.
The input I'm using is already pulled low so I shouldn't need the pull up resistor (like TK already suggested). Also, the power supply I'm thinking of using is 24VDC so I've re-sized the resistor to 1.2Kohms and .5W.
Could someone take a look at the two schematics a make sure their correct. Their located in the Attachments area in the 4n35 wiring folder.
Thanks again!
-Dennis
> +12V KFlop Gnd
> | _________ |
> | | | R = ~3kohm
> | |P3 P4|____
> | |_________| |
> - Router body
> > Hi Dennis,
> > +12V
> > 500 ohm
> > Opto LED pin 1
> > Opto LED pin 2
> > Touch Plate
> > Earth GND
> > DC GND
> > +3.3V
> > Opto Emmiter pin 6
> > Thanks guys!
> > Thanks,
> > Dennis
> > > Hi Dennis,
> > > + 3.3V
> > > 300 ohm
> > >    |  (long wire)
> > > Touch Plate/GND
> > > -Erik-
> > > > Thanks,
> > > > Dennis
> > > > > Regards,
> > > > > Ray L.
> > > > > > Thanks,
> > > > > > Dennis
> > > > > > > > Regards,
> > > > > > > > Ray L.
> > > > > > > > > Thanks,
> > > > > > > > > Dennis
Group: DynoMotion Message: 4032 From: Dennis Date: 2/21/2012
Sorry, the schematics are located in the Files area in the 4n35 folder...
Dennis
> Thanks again!
> -Dennis
> > +12V KFlop Gnd
> > | _________ |
> > | | | R = ~3kohm
> > | |P3 P4|____
> > | |_________| |
> > - Router body
> > > Hi Dennis,
> > > +12V
> > > 500 ohm
> > > Opto LED pin 1
> > > Opto LED pin 2
> > > Touch Plate
> > > Earth GND
> > > DC GND
> > > +3.3V
> > > Opto Emmiter pin 6
> > > Thanks guys!
> > > Thanks,
> > > Dennis
> > > > Hi Dennis,
> > > > + 3.3V
> > > > 300 ohm
> > > >    |  (long wire)
> > > > Touch Plate/GND
> > > > TK
> > > > -Erik-
> > > > > Thanks,
> > > > > Dennis
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Thanks,
> > > > > > > Dennis
> > > > > > > > > Regards,
> > > > > > > > > Ray L.
> > > > > > > > > > Thanks,
> > > > > > > > > > Dennis
Group: DynoMotion Message: 4037 From: quelisto Date: 2/22/2012
Ummm, I guess that will work, but it runs the risk of falsely going positive. How "stiff" is the pull-down resistor on the input? The reason it matters is that there will always be some "dark" current through the phototransistor. If you feed that into a high enough input impedance, you could go positive, or at the very least, it increases your sensitivity to triggering as you won't be sitting at ground potential. Let's put it this way: if you have 1 microamp of leakage current, with an input impedance of 1 megohm, that's 1 volt of offset...you've already used up 1/3 of your delta v for logic switching before you consider any other sources of interference.
If it were me, I'd Kflop ground the emitter and use a pull-up on the collector, and connect the Kflop input at the collector.
-Erik-
> Thanks again!
> -Dennis
> > +12V KFlop Gnd
> > | _________ |
> > | | | R = ~3kohm
> > | |P3 P4|____
> > | |_________| |
> > - Router body
> > > Hi Dennis,
> > > +12V
> > > 500 ohm
> > > Opto LED pin 1
> > > Opto LED pin 2
> > > Touch Plate
> > > Earth GND
> > > DC GND
> > > +3.3V
> > > Opto Emmiter pin 6
> > > Thanks guys!
> > > Thanks,
> > > Dennis
> > > > Hi Dennis,
> > > > + 3.3V
> > > > 300 ohm
> > > >    |  (long wire)
> > > > Touch Plate/GND
> > > > TK
> > > > -Erik-
> > > > > Thanks,
> > > > > Dennis
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Thanks,
> > > > > > > Dennis
> > > > > > > > > Regards,
> > > > > > > > > Ray L.
> > > > > > > > > > Thanks,
> > > > > > > > > > Dennis
Group: DynoMotion Message: 4041 From: Tom Kerekes Date: 2/22/2012
Hi Dennis,
Looks good to me.  But I would remove that capacitor from the base.
Group: DynoMotion Message: 4061 From: Dennis Date: 2/23/2012
The input that I'm using has a 150 ohm pull down resistor. What do you think? Would I still be better to go with the pull up resistor scenario?
-Dennis
> -Erik-
> > Thanks again!
> > -Dennis
> > > +12V KFlop Gnd
> > > | _________ |
> > > | | | R = ~3kohm
> > > | |P3 P4|____
> > > | |_________| |
> > > - Router body
> > > > Hi Dennis,
> > > > +12V
> > > > 500 ohm
> > > > Opto LED pin 1
> > > > Opto LED pin 2
> > > > Touch Plate
> > > > Earth GND
> > > > DC GND
> > > > +3.3V
> > > > Opto Emmiter pin 6
> > > > TK
> > > > Thanks guys!
> > > > Thanks,
> > > > Dennis
> > > > > Hi Dennis,
> > > > > + 3.3V
> > > > > 300 ohm
> > > > >    |  (long wire)
> > > > > Touch Plate/GND
> > > > > TK
> > > > > -Erik-
> > > > > > Thanks,
> > > > > > Dennis
> > > > > > > Regards,
> > > > > > > Ray L.
> > > > > > > > Thanks,
> > > > > > > > Dennis
> > > > > > > > > > Regards,
> > > > > > > > > > Ray L.
> > > > > > > > > > > Thanks,
> > > > > > > > > > > Dennis
